Engine data
https://slantsix.org/forum/viewtopic.php?t=56791
Author:  suitbear [ Fri Dec 26, 2014 5:25 am ]
Post subject:  Engine data
I have a 1960 Valiant with a slant six. When I bought it the seller said the engine was an engine from a 1965 car. He said it was not the 170 that was in the car originally. How can I verify that? Where can I go to search the block/head casting numbers to see if it is a 170 or a 225? Thank you for the info on this in advance.
Author:  ProCycle [ Fri Dec 26, 2014 8:01 am ]
Here's one helpful chart:
http://www.slantsix.org/articles/parts-matrix/jpg.htm
And check this thread:
http://www.slantsix.org/forum/viewtopic ... 471d7d3516
Author:  ceej [ Sat Dec 27, 2014 10:36 am ]
The block on the left is a 170, the one on the right is a 225.
The deck is much taller on the 225 block.
CJ
Author:  slantzilla [ Sat Dec 27, 2014 10:08 pm ]
Bypass hose between the head and water pump is about an inch long on a 170. It's about 3 inches on a 198/225.
