| Proper Engine lift bolt holes and Hardware https://slantsix.org/forum/viewtopic.php?t=56807 |
| Author: | neilskiw [ Sun Dec 28, 2014 10:14 am ] |
| Post subject: | Proper Engine lift bolt holes and Hardware |
Greetings. Can anyone post a pic or accurately describe proper lift technique for engine/trans lift from a Valiant? Does manifold combo need be removed? does this help/hinder due to balance concerns? Thanks for your expertise. |
| Author: | sandy in BC [ Sun Dec 28, 2014 1:25 pm ] |
Right beside the valve cover...in the middle of the head....are two threaded 3/8 bolt holes. Bolt a short length of chain between them . |
| Author: | se7enine [ Sun Dec 28, 2014 3:13 pm ] |
What he said ^^, just did this a couple weekends ago. Very easy and pulled it with a tractor. Not with the trans attached but with a leveler it might help. |
| Author: | nm9stheham [ Sun Dec 28, 2014 4:22 pm ] |
You can keep the manifolds on. 2" long 3/8" bolts coarse threaded with flat washers to spread the load on the links; grade 5 or grade 8, not ungraded. Have extra links in the chain length between the 2 bolts so you can adjust the point at which the hook attaches for balance; it also lowers the chain tension and side force on the bolts to have the extra links. A couple of pix here: http://www.forabodiesonly.com/mopar/sho ... p?t=300385 Trannie removed makes it easier IMO but you can do it with it attached; you can set the hook along the chain for the best angle. |
| Author: | neilskiw [ Sun Dec 28, 2014 5:00 pm ] |
Thanks very much to all of you. Happy new year!!! |
| Author: | Fopar [ Sun Dec 28, 2014 8:31 pm ] |
Copy from the other web site--- "Senior Member Join Date: Aug 2014 Location: Jasper,GA Posts: 231 Thanks: 19 Thanked 7 Times in 6 Posts Just did this a month or so ago. Like the other guys have said. 2 bolts sitting on top. Front one lifts and balances engine only. Back one balances engine and transmission together. Both work for almost perfect balancing." Richard |
