| Super six cast iron intake question https://slantsix.org/forum/viewtopic.php?t=5681 |
| Author: | Dave [ Tue May 06, 2003 5:47 pm ] |
| Post subject: | Super six cast iron intake question |
Made plate to cover egr opening and am curious as to has anyone gone the extra step to remove the cast pocket on the inside of manifold? |
| Author: | Doctor Dodge [ Tue May 06, 2003 10:21 pm ] |
I have rounded these over a little with a carbide "burr' but never spent the time to try to completely remove them. I do not think it hurts the flow all that much. (flow...what flow?? DD |
| Author: | Dave [ Wed May 07, 2003 3:43 pm ] |
Thanks DD for some reason it bothers me, or is it because of the new die grinder I just purchased? also when can we expect your artical on fuel rail construction, as am following your bung install to efi this super six. |
| Author: | Dad'sDart [ Wed May 07, 2003 4:18 pm ] |
| Post subject: | Capping EGR - any helpful hints? |
I have an aluminum intake that I'm about to do the same thing to. Does it make a difference what material I use to cap it? Also what's the recommendation on gasket for sealing? |
| Author: | Dave [ Wed May 07, 2003 4:38 pm ] |
| Post subject: | Capping material |
Don't see what the difference in material would make, used aluminum to fabricate mine using the EGR block as a guide, its just what I had on hand and is easy to work with, will be using high-temp sealant and reinstall using orginal studs. End of project. Other option is to cut the 4 rivets that retain the EGR to the existing plate and weld any holes closed and re-install, wish I would have thought of that first as I have the capacity to weld. |
| Author: | rrither [ Thu May 08, 2003 4:40 pm ] |
| Post subject: | Egr |
I did not use a plate on the outside. Drilled and tapped the hole inside under the carb mount to 1/2" pipe threads, and installed a flush pulg. I staked it in place, cleaned area and filled to top with JB weld. I installed a plug in the exhaust port (where the plate might go) the same way, only less the JB weld. That was 60,000 miles ago, I look down through the carb from time to time, its there to stay. |
