a727 shift shaft seal????
https://slantsix.org/forum/viewtopic.php?t=56817
Author:  hantayo13 [ Mon Dec 29, 2014 1:31 pm ]
Post subject:  a727 shift shaft seal????
the shift shaft is leaking where it enters case.....where do I get a new seal???? how do I replace it????
Author:  Reed [ Mon Dec 29, 2014 1:48 pm ]
You can pry the old one out with a pick or other small pointy object. New shifter shaft seals are available wherever trans parts are sold. I.E. http://www.makcotransmissionparts.com
Throttle lever seal
Shift linkage seal
Author:  slantzilla [ Mon Dec 29, 2014 11:10 pm ]
It can be done with the valve body in place, but it is a whole lt easier with it out, especially if the trans is still in the vehicle. :D
Author:  hantayo13 [ Thu Jan 01, 2015 8:19 am ]
found the parts ...waiting for them to get here....and a warm day to install
