It is currently Mon May 04, 2026 11:37 am
PostPosted: Tue May 06, 2003 8:48 am
Second gear is pissed off and the tranny leaks like mad. If Rpm's are perfect it shifts like a champ but otherwise does not like to go into 2nd. Downshifting from 3 to 2 is also not really an option. Any suggestions or Parts suppliers out there who can help??
PostPosted: Tue May 06, 2003 10:44 pm
The first step is to find-out what Mopar 3-speed is in the truck.
Once you have that info., call around to see if there are any used or rebuilt boxes available.
Sounds like you need a rebuild, a second gear syncrow, bearings and seals.
