| Nitrous tank safety https://slantsix.org/forum/viewtopic.php?t=56821 |
| Author: | MOUSETRAP [ Mon Dec 29, 2014 8:34 pm ] |
| Post subject: | Nitrous tank safety |
Can I leave a nos tank in the back of my station wagon in the summer sun ?? Tank would have a tank blanket on it not in direct sun and windows will have light or medium tint ... I would have a blow down tube on it .... Thanks |
| Author: | slantzilla [ Mon Dec 29, 2014 11:14 pm ] |
Not really a good idea. If the burst disc fails to rupture you could have a bad day. When I was spraying my Valiant I really had to be careful because the tank would build pressure pretty quickly in a closed trunk. |
| Author: | Charrlie_S [ Tue Dec 30, 2014 6:37 am ] |
I'm with Slantzilla, on this. During the summer, I keep a wet towel in the car, and put it over the tank, if the pressure gets over about 1050 lbs. I had a safety disk rupture on a tank, in the back of my pickup, on the way to a race. |
| Author: | MOUSETRAP [ Tue Dec 30, 2014 7:30 am ] |
Thanks makes for s easy choice ... If I had 1/2 bottle would that help ? Or not enough ..... |
| Author: | Charrlie_S [ Tue Dec 30, 2014 9:10 am ] |
On a ten lb bottle, it doesn't make any difference if there are 10 lbs in the bottle or 1 lb in the bottle, the pressure will be the same at the same temp. The only thing that will make a difference is, if the bottle is over full, it will burst easier, as there will be no "head" space, and will hydrolic. |
