It is currently Sat May 30, 2026 10:17 pm
PostPosted: Mon Jan 05, 2015 8:28 am
does this item fail a lot on slant hi per engines? would a custom steel one solve the issue if there is one?
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Jan 05, 2015 9:23 am
Are you talking about the retainer for the top half of the rear seal? :?
The front seal is in the timing cover. :shock:
PostPosted: Mon Jan 05, 2015 11:06 am
I guess it's aluminum with 2 bolts
slant six's RULE!
PostPosted: Mon Jan 05, 2015 3:58 pm
If it looks like this it's the rear seal:
PostPosted: Mon Jan 05, 2015 4:20 pm
yep that's the one/thanks !
slant six's RULE!
 Post subject: Lol...
PostPosted: Mon Jan 05, 2015 5:07 pm
The only failure is if you put the lip on the wrong side and don't follow Doc's article on setting it up correctly.
PostPosted: Mon Jan 05, 2015 6:21 pm
No.
No I don't think so - as I don't believe there is any issue with this part.
Its not load bearing Part - Just holds half of the seal in place.
