is the front aluminum seal main cap an failure issue?
https://slantsix.org/forum/viewtopic.php?t=56867
Author:  USAJon [ Mon Jan 05, 2015 8:28 am ]
Post subject:  is the front aluminum seal main cap an failure issue?
does this item fail a lot on slant hi per engines? would a custom steel one solve the issue if there is one?
Author:  slantzilla [ Mon Jan 05, 2015 9:23 am ]
Are you talking about the retainer for the top half of the rear seal? :?
The front seal is in the timing cover. :shock:
Author:  USAJon [ Mon Jan 05, 2015 11:06 am ]
I guess it's aluminum with 2 bolts
Author:  63Valiant [ Mon Jan 05, 2015 3:58 pm ]
If it looks like this it's the rear seal:
Author:  USAJon [ Mon Jan 05, 2015 4:20 pm ]
yep that's the one/thanks !
Author:  DusterIdiot [ Mon Jan 05, 2015 5:07 pm ]
Post subject:  Lol...
The only failure is if you put the lip on the wrong side and don't follow Doc's article on setting it up correctly.
Author:  Greg Ondayko [ Mon Jan 05, 2015 6:21 pm ]
Post subject:  Re: is the front aluminum seal main cap an failure issue?
No.
No I don't think so - as I don't believe there is any issue with this part.
Its not load bearing Part - Just holds half of the seal in place.
