/6 cyl head
https://slantsix.org/forum/viewtopic.php?t=56883
Author:  J S Goldman [ Thu Jan 08, 2015 12:57 pm ]
Post subject:  /6 cyl head
does any one know how much a / head with valves weigh?
Author:  Dart270 [ Thu Jan 08, 2015 4:24 pm ]
63-74 heads are around 68 lbs fully dressed. 75-79 heads are more like 76 lbs. 80-87 heads are about 70 lbs. These all vary by at least +/-2 lbs due to casting/year differences.
Author:  NEVjr [ Thu Jan 08, 2015 4:33 pm ]
i just weighed an early head (with the little dime sized lump in each chamber) and got 74.5 pounds
this is stock, used with some light carbon and grease, and includes manifold studs, rockers, shafts, valves, springs, spark plugs less 1, drool tubes less 1, and no gaskets, no valve cover
Author:  J S Goldman [ Thu Jan 08, 2015 5:40 pm ]
Post subject:  /6 head weight
thank you!
Author:  Dart270 [ Sat Jan 10, 2015 3:51 am ]
NEVjr,
Is that a 63-down head? I am surprised it is that heavy. Does it have the rocker shaft/gear on it?
Author:  NEVjr [ Sat Jan 10, 2015 7:41 am ]
it might be, how could i tell? its pre 68 for sure
that does include valve gear, like i listed, rockers, shafts, valves, etc
Author:  62 alum [ Sat Jan 10, 2015 9:23 am ]
This head is off a 64 slant complete from rocker cover to cast iron thermostat housing. 71 pounds give or take a pound or two for the old age of the scales.
Author:  J S Goldman [ Sat Jan 10, 2015 11:42 am ]
just an fyi my naked cleaned drull tube cyl head weighs 65 lbs.
Author:  Dart270 [ Sun Jan 11, 2015 4:18 am ]
OK, that makes sense. I was quoting weights with no rockers/shaft/bolts. That adds about 6 lbs. Very sorry I missed that in your earlier post.
