| how rare realy is a slant six 727? https://slantsix.org/forum/viewtopic.php?t=56975 |
| Author: | USAJon [ Sat Jan 24, 2015 7:16 am ] |
| Post subject: | how rare realy is a slant six 727? |
our 1983dodge ram 100 has a factory 727, I found the invoice from dodge to the dealership in the glove box, it has all the options including the 727 transmission listed, it also has a aluminum ring (flat like) washer taped to it with some numbers stamped on it...what that anywho? |
| Author: | Reed [ Sat Jan 24, 2015 7:52 am ] |
I don't have numbers for you, but in my almost 20 years of playing with slants I have only ever had my hands or eyes on TWO slant six specific 727. They are out there, but they are uncommon. |
| Author: | bcschief [ Sat Jan 24, 2015 7:53 am ] |
That aluminum ring with numbers is your key code for the door and ignition locks. Brian |
| Author: | Charrlie_S [ Sat Jan 24, 2015 8:03 am ] |
Actually, I have seen quite a few, in "fleet" (EI: police/taxi/etc) vehicles. |
| Author: | 65 dartman [ Sat Jan 24, 2015 8:03 am ] |
Friend of mine took a slant 727 to the recycler because he couldn't sell it. |
| Author: | USAJon [ Sat Jan 24, 2015 8:41 am ] |
thanks guys. just hauled some heavy cut firewood and the truck preformed great. even though the rear was low to the ground. http://slantsix.org/forum/viewtopic.php?p=420257#420257 |
| Author: | Greg Ondayko [ Sat Jan 24, 2015 11:52 am ] |
Quote: That aluminum ring with numbers is your key code for the door and ignition locks.
Am I missing something here? or does this actually have some relevance to the slant 6 727 Discussion?Brian Greg |
| Author: | bcschief [ Sat Jan 24, 2015 12:10 pm ] |
Quote: Quote: That aluminum ring with numbers is your key code for the door and ignition locks.
Am I missing something here? or does this actually have some relevance to the slant 6 727 Discussion?Brian Greg I was simply letting him know that tag was most likely his key code for the truck. Brian |
| Author: | biggyfries [ Sun Jan 25, 2015 3:04 am ] |
I'm a noob with my first slant six in my '86 Ram 150 Royale SE--it has an automatic in it--what do I have? What is the more common automatic? Where would I look to determine what trans I have? |
| Author: | GTS225 [ Sun Jan 25, 2015 5:36 am ] |
Biggy; You could try here; http://www.mymopar.com/downloads/transguide.pdf The shape of the trans pan will tell you. Roger |
| Author: | olafla [ Sun Jan 25, 2015 8:37 am ] |
Even on this side if the pond, I have the impression that a great number of vans and trucks came with a 727 behind the SL6. It may have to do with local vehicle weight classifications. I recently switched my 727 for a 904LA plus an extra converter. A 727 is noticeably heavier than a 904. Olaf |
| Author: | slantzilla [ Sun Jan 25, 2015 9:38 am ] |
I've had a few of them, both standard and lockup. I sold 1, the rest I had to give away. Yeah, the aluminum disc with the paperwork sounds like the key numbers to me also. |
