| 904 tranny serial numbers? https://slantsix.org/forum/viewtopic.php?t=56988 |
| Author: | DadTruck [ Sun Jan 25, 2015 6:30 pm ] |
| Post subject: | 904 tranny serial numbers? |
Picked up a 904 it is a large register stamped into the wall just above the pan is: PK 3681841 4681 4592 these numbers were stamped in really deep and ez to read and got these number off the small register 904 in the 68 Barracuda, 538368 Y 226 3297, same location as the tranny above the stamping on this case was very light,, not easy to see,, can anyone interpret these,, any info on date of manufacture,, maybe ratio info? thanks |
| Author: | DusterIdiot [ Sun Jan 25, 2015 7:15 pm ] |
| Post subject: | Here's a little bit of info... |
3681841 early‘74Charger,Dart&Valiant,6cyl. early‘74DodgePass.&PlymouthPass.,6cyl., A904 Given that, if the guts are still stock, it will have the typical A904 gear ratios. |
