oil pump gear
https://slantsix.org/forum/viewtopic.php?t=56991
Author:  '67 Dart 270 [ Mon Jan 26, 2015 8:05 am ]
Post subject:  oil pump gear
Some have suggested getting an OEM cam used and doing a regrind, particularly using the oil pump gear that was mated to the cam in the original engine. Sounds like a good idea.
Q: I have DD oil pump, can I swap out the gear itself, or do I have to swap out the whole shaft plus gear? I understand there are many designs of impellers on these pumps, so how do I swap out the gear?
Are there no good aftermarket cams out there?, what about comp cams or other name brands, are they all junk?
thanks all,
Brian
