| 1962 Valiant auto push button shifter https://slantsix.org/forum/viewtopic.php?t=57022 |
| Author: | crickhollow [ Sat Jan 31, 2015 11:50 pm ] |
| Post subject: | 1962 Valiant auto push button shifter |
How do you dismantle this unit? I need to replace one of the slides as the "finger" is broken ( I have another one for spares). I need to know how to remove the pin that slots trough all the slides and if I need to use another pin during the rebuild. Thanks |
| Author: | Doctor Dodge [ Sun Feb 01, 2015 7:17 am ] |
The factory serviced the PB shifter as an assembly only so it was not designed to be dis-assembled. With that said, you will have to remove the 4 small bolts that hold on the sheetmetal "back plate"... at that point, 5 springs come-out. Next you grind-off one of the crimped ends on the cross-pin, then slide that out, to free the Park plate & button "forks". It is best to have the unit clamped in a vise, with the button opening facing down so all the forks do not fall-out at once. Good luck... DD |
| Author: | crickhollow [ Sun Feb 01, 2015 12:59 pm ] |
Thanks DD. Given I need to grind off the end of the pin do you have advice on another source for a replacement pin. PF |
| Author: | Doctor Dodge [ Sun Feb 01, 2015 6:52 pm ] |
Do not cut the end of the pin off... just grind down the flattened tabs or "ears", just enough to slide the pin out... then re-use the same pin. DD |
| Author: | crickhollow [ Sun Feb 15, 2015 11:30 pm ] |
| Post subject: | push button mechanism |
i have repaired the broken 'finger' by using a spare I had. What is the best wat to crimp the pin end? Thanks, Peter |
