| water pump leaking from hole https://slantsix.org/forum/viewtopic.php?t=57026 |
| Author: | USAJon [ Sun Feb 01, 2015 5:52 pm ] |
| Post subject: | water pump leaking from hole |
what's a good replacement aluminum/steel ? |
| Author: | hantayo13 [ Sun Feb 01, 2015 6:13 pm ] |
"what's a good replacement aluminum/steel ?" one that doesnot leak |
| Author: | Doctor Dodge [ Sun Feb 01, 2015 6:42 pm ] |
These days... you would be lucky to find a cast iron housing water pump. A die cast alm. GMB pump, with the 8 fin impeller, is a common one we see today and those work well.. DD |
| Author: | Rick Covalt [ Sun Feb 01, 2015 7:23 pm ] |
Doug, is there any way to be sure and get the 8 fin impeller? I ordered the same part number at Advance 2 times and got one 8 fin and one 6 fin one. Rick |
| Author: | USAJon [ Mon Feb 02, 2015 2:16 am ] |
Quote: These days... you would be lucky to find a cast iron housing water pump.
I have a spare used one that does not leak.....A die cast alm. GMB pump, with the 8 fin impeller, is a common one we see today and those work well.. DD it's a 6 blade genuine Chrysler mid 1970's. |
| Author: | Doctor Dodge [ Mon Feb 02, 2015 8:26 am ] |
I also keep all my cast iron SL6 WP "cores"... and also re-use any good ones. Someday... I may find a way to rebuild the others. As for getting an 8 fin Al. WP, I just order and then look at the pump when it arrives. I tell the counter person to get me another, if I do not get an 8 fin. DD |
