| automatic transmission https://slantsix.org/forum/viewtopic.php?t=57065 |
| Author: | eastvan54 [ Sun Feb 08, 2015 8:01 pm ] |
| Post subject: | automatic transmission |
got me a 225 slant 6 - a904 automatic - the trannny takes some 30% of engine power to operate the tranny - am i right in this saying? - thinking of the standard a833 - though with my bad knees i might be stuck with the a904 - there is the a500 - with adaptability to the slant6 - the a904 even with upgrades i am not too sure - the car is a driver with a bit of attitude |
| Author: | SlantSixDan [ Sun Feb 08, 2015 9:19 pm ] |
| Post subject: | Re: automatic transmission |
Quote: got me a 225 slant 6 - a904 automatic
In what kind of vehicle, with how much wear and tear on it?Quote: the trannny takes some 30% of engine power to operate the tranny - am i right in this saying?
No, where did this number come from? The A904 takes vastly less than 30% of the engine power to operate. If the transmission were consuming 30% of the engine's power, it would get so hot it would melt into a heap of smoking slag.Quote: thinking of the standard a833
Big, expensive, difficult swap. Take you a long time to break even on it.Quote: there is the a500
What makes you think it takes less power to operate than an A904 which is identical except for the lack of the 4th gear?Quote: with adaptability to the slant6
Kinda-sorta. It can be done, but you're looking at floor pan mods, crossmember mods, custom driveshaft, custom controller...this is another big, expensive, involved swap.Quote: the a904 even with upgrades i am not too sure
Not too sure about what, exactly? The A904 is an excellent, very efficient transmission.
| Author: | eastvan54 [ Sun Feb 08, 2015 10:02 pm ] |
have a 75 2 door dart swinger - doing a restoration - what about the upgrades for the a904 - i am sure that perhaps adding or better yet improving the tranny would be the best way to go - |
| Author: | SlantSixDan [ Sun Feb 08, 2015 10:11 pm ] |
What improvements are you trying for...? What do you want it to do that it doesn't presently do, or not-do that it presently does, or do differently? |
| Author: | Reed [ Sun Feb 08, 2015 11:10 pm ] |
For a daily driven 75 Dart the only modifications I recommend being made during a full rebuild are (1) make sure the 904 has part throttle kick down and (2) install a shift kit. Otherwise, leave it alone. Like Dan said, the 904 is a VERY well designed and durable transmission. |
