It is currently Tue Nov 17, 2026 11:37 am
 Post subject: does anyone know?..
PostPosted: Tue Aug 15, 2006 8:30 pm
i have a 73 swinger have jsut got into car rebuilding and such.my questino has to do with big bolt patterns and small ones? how can i tell the difference? ..or does anyone know what bolt pattern they came with?
ps i have disc brakes in the front and drum in the back
________
Michigan medical marijuana dispensaries
________
MEDICAL MARIJUANA STATES
Last edited by 15Standtriumphant on Thu Feb 17, 2011 6:45 am, edited 2 times in total.
PostPosted: Tue Aug 15, 2006 11:11 pm
Small Bolt Pattern (SBP) and Large Bolt Pattern refers to the diameter of an imaginary circle that passes through the lug bolts. Once you see them both, you will be able to determine by sight. The simple way to measure is find the distance from the center of one lug to the outer edge of the one opposite it. SBP should measure 4" diameter and LBP should measure 4-1/2", hence the terms "5 on 4" and "5 on 4-1/2" (the "5" refers to the number of lugs.)
Disk brakes on the front of my son's '74 Dart Sport were swapped over from a '76 Duster, and they are LBP. Someone else here will have to address your question of which years had the various lug patterns.
Jerry
PostPosted: Wed Aug 16, 2006 12:17 am
'73 was the first year for the large bolt pattern disc brakes. That's 5 on 4.5" bolt circle.
