67 Vert brake line question
https://slantsix.org/forum/viewtopic.php?t=57100
Page 1 of 1
Author:  67slantvert [ Sun Feb 15, 2015 6:16 pm ]
Post subject:  67 Vert brake line question
Hello Everyone,
A few months ago I bought a 67 dart convertible that was a "basket case" as in everything was torn apart and in a basket.
I am slowly rebuilding and putting it together. I need some info on the steel preformed brake lines. I has standard drums all around and all of the front lines were pulled. The front to rear line is a 2 piece set up can anyone tell me if that is right or is it supposed to be the 1 line??
I found kits online but the only ones with a 2 piece front to rear are the disc brake sets.
Author:  DusterIdiot [ Sun Feb 15, 2015 7:10 pm ]
Post subject:  6 parts...
'67 to '76 A-bodies get:
1) 2 lines from the dual master cylinder to the metering block
2) 1 line from the metering block to the driver's front wheel
3) 1 line from the metering block to the passenger front wheel
4) 1 line from the metering block to the "hump" where the rear axle is housed...then it goes to a hose with two outlets..
5) 2 lines from the dual outlet to each wheel clipped to the axle housing
Typically premanufactured brakelines will get you #2,3,4 in the list, with the option to buy #1 separately.
