| Tach/Dwell/Voltmeter https://slantsix.org/forum/viewtopic.php?t=5711 |
| Author: | Seis Inclinado [ Fri May 09, 2003 3:50 pm ] |
| Post subject: | Tach/Dwell/Voltmeter |
Engine does not miss at any speed. What can be wrong? Igniton coil, distributor pick up coil, ECU...? Is any of these three units going south? Any ideas? As for emissions today Rafa |
| Author: | Pierre [ Fri May 09, 2003 4:18 pm ] |
Is this the kind of tach that hooks up to the - of coil, or gets its signal off of a spark plug pickup like a timing light? Make sure you have the right # of cylinders selected. |
| Author: | Seis Inclinado [ Sat May 10, 2003 12:30 am ] |
Pierre It has one function selector with three positions, Volts-Dwell-RPM, one scale for volts. Two scales for RPM and two scales for dwell one for 8 cyl and one for 6 cyl engines. For 4 cyl engines read double the 8 cyl engine reading. Rafa |
