It is currently Wed Jun 10, 2026 9:15 pm
PostPosted: Sat Feb 28, 2015 10:37 am
I am working on removing the block drain plug.
The engine is a 66, I think, and the plug probably has never been out.
I removed the paint from the threads and soaked it in penetrating oil for a week. The engine is in the car.
I got the right front wheel off.
I am using a manual impact wrench, a few extensions, and a sledge hammer.
Is it possible to crack the block this way?
The impact socket is right up against the block.
UPDATE:
I put a breaker bar on it and it didn't move.
Then I hit the breaker bar while putting 50-60 foot-pounds of pressure on it, and it came loose!
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
