| Rebuilt cylinder head from Advance Auto https://slantsix.org/forum/viewtopic.php?t=57121 |
| Author: | Steve-Maine [ Wed Feb 18, 2015 3:34 pm ] |
| Post subject: | Rebuilt cylinder head from Advance Auto |
I found a rebuilt cylinder head for my 225 engine at Advance auto for $318 outright or return core for $50. Are there heads any good and is this a good prices with valves? |
| Author: | SlantSixDan [ Wed Feb 18, 2015 3:57 pm ] |
Unless I were in truly desperate need and the only thing that mattered was having a cylinder head, any cylinder head, right this minute…I'd not touch a parts store item like this with the proverbial 3.048-metre pole. |
| Author: | Danarchy [ Wed Feb 18, 2015 5:17 pm ] |
Quote: 3.048-metre pole Canadians |
| Author: | Doctor Dodge [ Thu Feb 19, 2015 8:54 am ] |
I have seen "production shop" heads that were a pretty good value but it was a "you got what you paid for" deal. Most have been dis-assembled, cleaned, the used valves had been re-faced and the guides were knurled to get them tight again. The head is reassembled with the used retainers, keepers & valve springs, with spring shims added, along with new valve stem seals. Done. The "better" ones were resurfaced with a "clean-up" cut and some even have all the guides sleeved and the used valve stems ground undersize to fit. When I get one of these heads, I check the cc's, then dis-assemble & redo everything. Basically... I get the cleaning and a set of new valve stem seals for my money. ( and maybe a surface job & some lined & undersize guides to work with) DD |
