| thermostat housing https://slantsix.org/forum/viewtopic.php?t=57161 |
| Author: | '67 Dart 270 [ Tue Feb 24, 2015 5:11 pm ] |
| Post subject: | thermostat housing |
I've seen many SL6's with a thermostat housing.neck that is 180 degree, not 90 deg, where does one get one of those? I've read Ford and other ones might interchange. I have a home made double 90 degree neck, it works fine, but I was thinking of trying a "straight out" option. thanks, Brian |
| Author: | Rick Covalt [ Tue Feb 24, 2015 5:34 pm ] |
Quote: New thermostat housing for later V-8 car works fine except you need to drill the mounting holes out to slant 6 size. Mine came from Summit ( Summit Racing Part Number: FSS-84909 )
| Author: | '67 Dart 270 [ Tue Feb 24, 2015 5:34 pm ] |
| Post subject: | does the V8 mopar small block neck fit? |
Seems like that might be the same fitment... |
| Author: | Pierre [ Tue Feb 24, 2015 6:10 pm ] |
Yes. That's what I have on my car. Just make sure it's from a year they used the same size thermostats... at one point they switched over to an obviously bigger size. |
| Author: | '67 Dart 270 [ Tue Feb 24, 2015 7:03 pm ] |
| Post subject: | does the thermostat fit in OK? |
Looks like that one might not fit the thermostat, does it? brian |
| Author: | DadTruck [ Tue Feb 24, 2015 7:09 pm ] |
'thermostat housing.neck that is 180 degree' 70's - and maybe later mopar v8's from the local pull a part[/quote] |
| Author: | '67 Dart 270 [ Tue Feb 24, 2015 7:12 pm ] |
| Post subject: | Thanks, great! |
Found it. |
| Author: | Rick Covalt [ Wed Feb 25, 2015 2:28 am ] |
http://slantsix.org/forum/viewtopic.php ... ing#382830 The one I posted is a straight housing and does fit the standard thermostat. See the link above. |
| Author: | '67 Dart 270 [ Wed Feb 25, 2015 11:40 am ] |
| Post subject: | Thanks! |
Excellent help, thanks Rick. brian |
| Author: | '67 Dart 270 [ Wed Feb 25, 2015 11:45 am ] |
| Post subject: | ...especially the lower hose bit.. |
I was using an ugly flex hose down there... brian |
