It is currently Tue Jul 07, 2026 6:48 am
PostPosted: Sat Mar 21, 2015 7:50 am
I want to remove all frame rails as they are good.is there a method/saws all, torch that is best /I can roll car on side or upside down . is the a video of such stuff , I could not find one. thanks you. any one need frame rails, I need the right rear only.
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Mar 21, 2015 1:38 pm
Get a spot weld cutter for your drill and cut them out properly. You will see the holes in the flanges where they are spot welded on. :D
