high pitch noise while accelorating
https://slantsix.org/forum/viewtopic.php?t=57278
Page 1 of 2
Author:  camiking23 [ Sat Mar 14, 2015 11:12 am ]
Post subject:  high pitch noise while accelorating
There is a high pitched noise when I am accelerating into what sounds like high rpms. (No tach installed) is it bad? I have a 99 Durango with a 318 and dose this in the 3500+ range.
SL6 4bbl Holley 727 auto
Author:  SlantSixDan [ Sat Mar 14, 2015 11:25 am ]
Check to see if someone installed a turbocharger or supercharger while you weren't looking.
Author:  Doctor Dodge [ Sat Mar 14, 2015 11:36 am ]
Check the oil level in the rear end.
Author:  camiking23 [ Sat Mar 14, 2015 12:06 pm ]
I wish they had but how to check the oil level
Author:  Reed [ Sat Mar 14, 2015 12:23 pm ]
Do you mean, "How do I check the oil level in the rear axle of my 99 Durango?"
If so, there will be a fill plug on the side of the center section of the axle. With the truck sitting level, remove the plug and stick your finger in the hole. The axle gear lube oil should be even with the bottom of the fill hole.
Author:  camiking23 [ Sat Mar 14, 2015 1:50 pm ]
Not of the Durango. I ment the D150 I was referring to the Durango as in it makes the same noise during 3500+ rmps
Author:  Reed [ Sat Mar 14, 2015 1:52 pm ]
The same instructions apply.
Author:  camiking23 [ Sat Mar 14, 2015 2:20 pm ]
Level meaning not jacked up
Author:  Reed [ Sat Mar 14, 2015 2:33 pm ]
Level meaning parked on flat ground with the suspension holding the full weight of the vehicle. If the truck is on a hoist that lifts the frame and lets the axle drop and dangle from the rear springs, then the oil level should be about 1/4 inch below the plug hole. If you have any question then just make sure the oil is between the bottom of the fill hole and 1/4 inch below the bottom of the hole.
Again, I thought you said you had a shop manual for your truck?
Author:  camiking23 [ Sat Mar 14, 2015 4:45 pm ]
I do but can't seem to remember where I placed it last
Author:  nm9stheham [ Sat Mar 14, 2015 5:48 pm ]
Can you describe this high pitched noise any better? Is it a smooth whistle or a grinding high pitched noise or shrieking/squeaking noise, or what?
Author:  camiking23 [ Sat Mar 14, 2015 6:38 pm ]
It's like a whistle I guess I hear it only when in holding the petal to the floor or switching gears only in drive. When in park I can rev all I want and no noise
Author:  GTS225 [ Sat Mar 14, 2015 7:28 pm ]
Does the whistle change pitch when the truck shift gears?
Do you have an aftermarket sound system installed?
I ask, because fairly often the alternator will make an electronically-induced whine or whistle in the stereo as you described. Most times, it's not very loud, but is noticable.
Roger
Author:  camiking23 [ Sun Mar 15, 2015 6:42 am ]
I have an aftermarket radio and equalizer. It was a sound system but took it out months ago
Author:  cpslntdchrg [ Sun Mar 15, 2015 7:04 am ]
To remove the oil plug in the rear differential you can use a 1/2 rachet (at least in my car). Plug it directly on the plug's square notch, or use an extension if it is too difficult to reach. Then, check the oil level is at the plug's hole bottom (almost overflowing). if not fill it up to that level. Use differential oil.
Page 1 of 2 All times are UTC-07:00
