It is currently Sat May 23, 2026 11:20 pm
 Post subject: Spring time wake up
PostPosted: Sun Mar 08, 2015 2:06 pm
Well , still got snow up to my ass, but temps are up enough to get my 51 Cambridge awake again. What im looking for is the largest oil filter i can get. Part numbers makes etc. Also plug size and gap recommendations both for 80 diplomat sl6. Thanks
51 Plymouth Cambridge with / 6
 Post subject: It's...
PostPosted: Sun Mar 08, 2015 2:15 pm
Oil Filter Wix 51515 should be plenty enough for you...
Plugs: NGK-UR-5
Points or Stock EI :.035 gap...
Running performance coil/wires/GM HEi Module or Mopar Orange Box: gap at .040 - .045
PostPosted: Sun Mar 08, 2015 4:11 pm
Thanks, meant to mention i use wix
 Post subject: Or
PostPosted: Sun Mar 08, 2015 5:45 pm
Or, go with the WIX 51806........................I just did an oil change on the Valiant today! and used this filter.
 Post subject: First...
PostPosted: Sun Mar 08, 2015 6:01 pm
He needs to determine of he has an oil pump standpipe or the threaded nub, 51515 if a standpipe or 51806 if no standpipe...
PostPosted: Sun Mar 08, 2015 6:43 pm
51773 is the bigger filter, 2qts. Comes all the way up to the head and then a bit. Watch your fluid level with this guy.
I've come to dislike the pump with standpipe built in. I'd much rather use no standpipe on the pump and have a 51806 - makes oil changes less messy.
PostPosted: Mon Mar 09, 2015 4:44 pm
Ok, i will pull old filter this weekend
 Post subject: Careful...
PostPosted: Mon Mar 09, 2015 6:26 pm
I would dry test this guy, some of the oil pump castings are a little off and although some of the block castings have a little "dip" near the head to clear the taller filter, if the casting is off a little you can not be able to get a good grip on it to get it off... on the melling pumps I've had a few that were a little tight with the 51515...OEM casting-no problem.
PostPosted: Sun Mar 15, 2015 7:39 am
Well another week delay. snowing and blowing. Anyhow, i can see a long napaonline filter on it. The stock short filter is 51068
