| Aftermarket Oil sending unit https://slantsix.org/forum/viewtopic.php?t=57305 |
| Author: | camiking23 [ Tue Mar 17, 2015 8:57 pm ] |
| Post subject: | Aftermarket Oil sending unit |
I brought an aftermarket oil gauge and none of the adapters fit on the oil pump housing. Somebody help me with this issue. |
| Author: | Serj22 [ Tue Mar 17, 2015 9:04 pm ] |
Are none of the adapters supplied a 3/8" npt? If not none of them will fit. You can "T" off the spot with some pipe fittings that will allow the oil sender light sensor, and the gauge to function simultaneously. |
| Author: | '67 Dart 270 [ Tue Mar 17, 2015 10:38 pm ] |
| Post subject: | pipe fittings |
These should be standard SAE npt pipe fittings, I'm surprised they aren't included with the kit. Are they metric or something? |
