| Too fast of an advance curve? https://slantsix.org/forum/viewtopic.php?t=57325 |
| Author: | dartsport76 [ Thu Mar 19, 2015 7:12 pm ] |
| Post subject: | Too fast of an advance curve? |
What are the downfalls of running too fast of an advance curve? How can I tell if the curve is too fast? I'm assuming if it's too slow it'll be noticeable seat-of-pants wise? Reason I ask, is I put the yellow and blue springs (lightest and second lightest) from bigslant6fan's spring kit in my Dart (mild slant, stock stall, 2.76 gear w/24" tire) and I'm under the impression that it's too fast. I idle around 600, and advance don't start till 900 according to his graph... I'm also under the impression that you want a 2 stage advance, not two springs of the same rate? Would blue and green be better? I've got super six and '76 springs too. So is this too fast? Should I want advance to be higher than my choke idle? Please bare with me, it's just taking me a while to wrap my brain around some of this I guess |
| Author: | Joshie225 [ Fri Mar 20, 2015 10:27 am ] |
Cons of too much timing advance: Cylinder pressure peaks too soon doing negative work on the piston. Seen mostly as a power loss. Pinging/detonation. If excessive can cause engine damage and loss of fuel economy. Emissions. Advanced timing leads to higher combustion temperatures and an increase in NOX emissions. A 2-stage advance can help top end power as more timing advance can be tolerated and useful above the peak torque RPM. |
| Author: | sandy in BC [ Fri Mar 20, 2015 11:24 am ] |
I plan an advance curve this way: I figure the amount of total advance I want at peak torque (example sbc 34degrees) I figure what static advance I need to start the thing (sbc 10:1cr 8 degrees) that means my advance curve starts just off idle and increases by a total of 34 minus 8 = 26 degrees of mechanical advance. Plug in vac advance to get more advance at an idle and cruise. The transition from idle.... static + vacuum ......to static + vacuum + mechanical is where stumbles and bog begin and end. The stomp of the pedal causes the vacuum part of the advance to disappear ,,,,so you need a good part of your mechanical advance to be added right away....then level off to your peak torque RPM ( 2000 - 2200 rpm) |
| Author: | 63valconvert [ Fri Mar 20, 2015 11:45 am ] |
I just put the Blue (for the lightest) and Black springs in my distributor. Definite pinging there at WOT. Even at half. I have a short slot distributor and the 8.5 can on it, but I haven't had the slot welded to .38 yet. That's my next plan. It tried the green/black combo, too, and the blue is far peppier. |
| Author: | '67 Dart 270 [ Wed Mar 25, 2015 4:29 pm ] |
| Post subject: | blue and green |
I use the blue and green combo, seems to work well, no pinging, it goes all in by 2600rpm or thereabouts. brian |
| Author: | dartsport76 [ Wed Mar 25, 2015 7:05 pm ] |
Yep, I swapped the yellow for a green, and bumped the initial from 6*BTDC to 8, and it seemed to like it. Ran better than it ever had. Then I melted a hole the #3. Not sure that was the cause tho. Teardown and investigation happening shortly, another thread with some more questions on the way. |
