| cutting up an 1973 dodge dart sport https://slantsix.org/forum/viewtopic.php?t=57336 |
| Author: | USAJon [ Sat Mar 21, 2015 7:50 am ] |
| Post subject: | cutting up an 1973 dodge dart sport |
I want to remove all frame rails as they are good.is there a method/saws all, torch that is best /I can roll car on side or upside down . is the a video of such stuff , I could not find one. thanks you. any one need frame rails, I need the right rear only. |
| Author: | slantzilla [ Sat Mar 21, 2015 1:38 pm ] |
Get a spot weld cutter for your drill and cut them out properly. You will see the holes in the flanges where they are spot welded on. |
