cable shift /6 904 guts interchangable?
https://slantsix.org/forum/viewtopic.php?t=57381
Author:  NEVjr [ Fri Mar 27, 2015 8:42 pm ]
Post subject:  cable shift /6 904 guts interchangable?
how much stuff is interchangeable into a 62 904 case from a post-64 V8 904 trans? i have a well built 904 for a small block that i would like to use as much stuff from in my 62 case, what wont work, the valve body i guess, but the gears and clutches, etc?
Author:  SlantSixDan [ Fri Mar 27, 2015 10:02 pm ]
How far "post '64" are we talking about? Almost everything swaps in from a '65. Less stuff swaps in from a '66 or newer.
Author:  NEVjr [ Fri Mar 27, 2015 11:09 pm ]
post 65 for sure, maybe 68? im not near it to check right now
Author:  Charrlie_S [ Sat Mar 28, 2015 5:57 am ]
If I remember correctly, the only parts that swap, after 1967, is the front section. Input, pump, clutch assemblys. Everything from the planetarys back will not swap. If you swap the front section, you will need the later torque converter. The later converter will not fit the early engine, unless you get a custom converter.
Author:  SpaceFrank [ Sat Mar 28, 2015 11:51 am ]
On a slightly different note, I have a '64 cable-shift 904. What parts would need to be swapped in order to increase the number of clutch discs from stock? Can these parts be taken from a '67 and down V8 904 to avoid changing the torque converter?
