It is currently Sat Nov 21, 2026 6:07 pm
PostPosted: Thu May 08, 2003 6:53 am
Hello folks, i have a cracked exhaust manifold and i'm looking for some options. While it is cracked i'm thinking this is the time to do something i have been thinking about. I want to run dual exhaust and make my duster louder. What are my options and how much should i expect to save for this job. Thank you in advance for your input.
RP
PostPosted: Thu May 08, 2003 9:04 am
It may be the time to get some "Dutra Duals"
http://www.slantsix.org/articles/exhaus ... d-mods.htm
PostPosted: Thu May 08, 2003 12:32 pm
Thanks for the input.. i will look into it...
PostPosted: Mon May 19, 2003 9:08 am
Anybody running straight pipes, front to back with a Y splitter?
I heard the glasspack and it is not loud enough, i have not heard straight pipes yet..
I'm in NJ, anybody around here running this setup or something similar?
I miss my motorcycle and i need to hear some rumble without dropping an 8 in there..
thanks in advance.
PostPosted: Mon May 19, 2003 9:22 am
Un-bolt the head pipe from the manifold and see if that is loud enough for you! :shock:
I hope you live out in the country where no one is around to hear the racket.
PostPosted: Mon May 19, 2003 9:38 am
I used to live in NJ. I have dual headers and glasspacks. If I hade this setup on a car in NJ, I Couldn't afford to drive it, for the tickets, for loud exhaust.
PostPosted: Mon May 19, 2003 10:43 am
Doc: I think i'll try that first...
Charrlie: I see guys driving around with some loud cars, i just don't know what they are running... i have to listen to the type of setup you are running..
thanks
