| harmonic dampener inquiry https://slantsix.org/forum/viewtopic.php?t=57439 |
| Author: | ValiantBoyWonder [ Sat Apr 04, 2015 7:03 pm ] |
| Post subject: | harmonic dampener inquiry |
i have a 70 valiant with the Air Conditioning 3 groove pulley. as i recall, the outer 2 pulley assemble bolts directly to the harmonic balancer correct? so if i were to pick up the 3 pulley balancer that came on mid 70's trucks (that dan recommended) would this work out ok? does it make a difference that i have a forged crank? |
| Author: | Reed [ Sat Apr 04, 2015 7:38 pm ] |
Dan's recommended pulley would work fine. However, the power steering pulley bolted to the radiator side of the damper and the AC compressor pulley bolted to the engine side of the damper. |
