| Trans shifts? https://slantsix.org/forum/viewtopic.php?t=57450 |
| Author: | GTS225 [ Sun Apr 05, 2015 6:58 pm ] |
| Post subject: | Trans shifts? |
Did a search, but my problem doesn't seem to fit into others I found. Sit-rep; T-bucket, 225/904, '59 Chevy rear with (about) 3:08 gearing. Trans seems to upshift late and downshift early. (I do need to double-check the fluid level.) If my foggy memory is correct, that suggests the kickdown is adjusted too far and needs to be backed off a bit. Opinions? Roger |
| Author: | SlantSixDan [ Sun Apr 05, 2015 7:42 pm ] |
I agree with your conclusion. |
| Author: | GTS225 [ Mon Apr 06, 2015 3:51 am ] |
Thank You, Dan Roger |
