1985 D150 needs ignition control module
https://slantsix.org/forum/viewtopic.php?t=57487
Author:  Tim Keith [ Sun Apr 12, 2015 10:42 pm ]
Post subject:  1985 D150 needs ignition control module
I think it would be better to convert to HEI. The truck does not have the Chrysler ignition module. That explains why there is no spark :(
Author:  xjarhead [ Mon Apr 13, 2015 12:48 pm ]
On my 86 the computer is mounted under the fender behind the battery.
Here is how i did the HEI conversion on mine.
http://1drv.ms/1DSutGA
Dave
Author:  Tim Keith [ Tue Apr 14, 2015 7:46 pm ]
The control module is under the fender too. I have the FSM and it shows the control module near the brake vacuum booster, about where I have some loose connectors that I now don't know what those are for. I have power to the coil, but there is no spark.
I'm still going to do the HEI conversion.
Author:  xjarhead [ Thu Apr 16, 2015 10:37 am ]
Can you post pictures of the loose connectors?
Is the control module look similar to this? http://1drv.ms/1J7N8fP
Remember mines had computer guts removed and heat sink and HEI installed in it's place
Are the connectors shaped like the one's that are on page D10 outlined in a red dotted line?
Scroll to the bottom of the document. http://1drv.ms/1GPCzRf
Dave
Author:  Tim Keith [ Sun Apr 26, 2015 5:16 pm ]
I fixed a loose connection that goes to the distributor. When I hit the ignition key I didn't hear the motor crank, it fired immediately and is running smoothly. I did not choke the carb. This is the first time that I had heard this motor running.
The motor has a leak in the exhaust manifold, the truck had set up for about two years.
I will get around to the HEI conversion...
