| Who runs tubes in slicks? https://slantsix.org/forum/viewtopic.php?t=57489 |
| Author: | Ron Hamby [ Mon Apr 13, 2015 5:55 am ] |
| Post subject: | Who runs tubes in slicks? |
Just wanted to get a poll from you guys. Explain why you do or don't run them if you don't mind. Tks Ron |
| Author: | Greg Ondayko [ Mon Apr 13, 2015 6:09 am ] |
I dont, Other than the extra weight, I see no reason Not too. I wonder if they are more consistent in the 60' Etc? My slicks hold air well with no tubes. Greg |
| Author: | slantzilla [ Mon Apr 13, 2015 7:53 am ] |
Unless you have a car that really hits the sidewalls I would not bother. |
| Author: | Charrlie_S [ Mon Apr 13, 2015 10:06 am ] |
See what the tire maker recommends. The small M&H slicks on my Cuda require tubes. The problem is they are 22x8x13, and no one has a tube available that will fit. The tires actually leak air out the sidewall, by about 5 lbs a day. M&H told me to coat the inside of the tire with Dawn dish washing detergent. It works. But why can't the company, put something in the tire to prevent the problem? |
| Author: | Nicademas [ Mon Apr 13, 2015 1:26 pm ] |
Quote: But why can't the company, put something in the tire to prevent the problem?
Like a bead lock? LOL sorry just had to....I use used stock car tires. There a little hard but they do the job. And I can get 4 for $60. |
| Author: | ProCycle [ Mon Apr 13, 2015 1:39 pm ] |
Quote: But why can't the company, put something in the tire to prevent the problem? I run a small amount (2 oz.) of 'Slime' in my street tires. They will go for a years without needing any topping up with air.
| Author: | madmax/6 [ Wed Apr 15, 2015 9:06 am ] |
No tubes,I do coat the inside of the tires with Dawn dish soap. |
