It is currently Wed Aug 26, 2026 2:47 pm
PostPosted: Fri Apr 17, 2015 11:40 pm
OK, so by now most of you know that I've had two cam/oil pump gear failures in a relatively short time, so please bear with me if I'm going overboard here...
I'm fabricating my cam stop and I have two timing covers from which to choose. I have mine which has a lot of pitting after cleaning the rust, so DD was nice enough to give me a rust free one. But...
First thing I did was find a great lock nut to weld on. After a few choices, I settled on this one because it is a meaty 11/16" and has a nice flange that should make welding it to the cover much easier, and the distortion to make it a lock nut is in the middle of the nut's side, so I can weld it flange down (or flange up if I had wanted to):
http://s785.photobucket.com/user/67dart ... sort=3&o=3
http://s785.photobucket.com/user/67dart ... sort=3&o=2
So, I take the less pitted timing cover, mark my spot, drill my hole, and crank down the nut in place with an adjuster and a nut on the other side. It doesn't mount straight because of the ridges in the cover put there to impart rigidity, so I flatten the area around the hole so the nut will lie flat:
http://s785.photobucket.com/user/67dart ... sort=3&o=7
http://s785.photobucket.com/user/67dart ... sort=3&o=1
Of course, then I notice that not only does the area I flattened put more flex in the cover (duh), I also notice that this cover's ridges are not very pronounced and the cover as a whole has a lot of flex in it. How is the cam stop supposed to stop the cam from moving forward?
So, I look at my more pitted cover and see that it has way more pronounced ridges and way less flex:
http://s785.photobucket.com/user/67dart ... sort=3&o=6
So, I used that one for the cam button. As you can see from the above picture. What is all that extra discoloration from heating you ask?
Wait, first here's a close up of the nut welded onto the more rigid cover, and I didn't flatten any of the ridges:
http://s785.photobucket.com/user/67dart ... sort=3&o=5
OK, back to the obvious indications of heating over a large area.... as an over engineering step, on the other side I (my buddy, actually) welded an 1/8" thick steel plate to the inside for even more rigidity. I took a 4" x 4" steel plate, drilled a 1.5" hole in the middle, then cut off the corners, so it wouldn't interfere with the timing chain sprocket. Then my buddy welded it to the inside:
http://s785.photobucket.com/user/67dart ... sort=3&o=4
My timing cover is just a tad heavier than typical, but boy is that thing rigid, the flex in that area is essentially gone.
Now onto my oiling tube decision. Maybe I won't over engineer that...
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Apr 18, 2015 12:25 am
Gotta ask................
Will it clear the chain?
:oops:
 Post subject: yes..
PostPosted: Sat Apr 18, 2015 9:27 am
The plate is more than 1/4" within the chain sprocket's inside edge, way clear of the chain and sprocket. More than 1/8" between the thick washer holding the sprocket and at about 1/4" between the sprocket's main body and the plate.
brian
 Post subject: seal
PostPosted: Sat Apr 18, 2015 12:49 pm
I'm gonna change that seal though, that cover got pretty hot when he was welding it...
 Post subject: clarification..
PostPosted: Sat Apr 18, 2015 6:48 pm
The 1.5" hole in the center of the plate more than accommodates the head of the cam bolt, so it is about 1/4" from the cover, but for the adjuster which is set at 0.005". The washer that holds down the sprocket/pin is about 1/4" away from the plate we welded in. There is plenty of room for this mod.
I put a very thin film of pattern grease on the tip of the adjuster:
http://s785.photobucket.com/user/67dart ... i.jpg.html
When I bolt down the cover, with the dampener tool centering the cover seal, the adjuster mated perfectly centered with the cam bolt:
http://s785.photobucket.com/user/67dart ... u.jpg.html
I had to use a rat tail file on a couple of the timing cover bolt holes, widen them a bit so the bolts didn't move the cover and misalign the adjuster on the bolt.
The old double timing chain had a lot of play in the downstream side, but this Aussie one is snug.
brian
