| Straight-out waterneck for Slant found (thanks C-dog) https://slantsix.org/forum/viewtopic.php?t=5759 |
| Author: | Dart270 [ Wed May 14, 2003 7:13 am ] |
| Post subject: | Straight-out waterneck for Slant found (thanks C-dog) |
Hey folks, Well, Cycledog did some boneyard searching and found that an '88 5th ave 318 "straight out" waterneck fits the Slant essentially perfectly. This should be found on '80s-'90s SB Mopars, and only needs the bolt holes drilled slightly. They use the same gasket as the Slant and the same thermostat type. Thanks C-dog! <BR><IMG SRC=http://images.prosperpoint.com/518/26910-153.jpg WIDTH=275 HEIGHT=240>[/img][/list] These are listed new at Rockauto.com for $6, and I verified that the part numbers for gasket and thermostat are the same as the Slant Six. I will be putting one of these on my '64 Dart soon. Cheers, Lou |
| Author: | Wesola78 [ Wed May 14, 2003 2:47 pm ] |
| Author: | Dart270 [ Wed May 14, 2003 6:50 pm ] |
Cycledog is the one to thank. This is only good for non-OEM radiator setups like the aluminum one I have on my '64. Cheers, Lou |
