| small register to large crank register adapter question https://slantsix.org/forum/viewtopic.php?t=57590 |
| Author: | DadTruck [ Mon Apr 27, 2015 6:39 pm ] |
| Post subject: | small register to large crank register adapter question |
I plan to re install the engine back into the 68 barracuda this weekend. i.e. small register tranny (67 and down) & large register crank ( 68 and up) for the adapter ring that fits the the small register tranny to the large register crank. does the adapter 'snap' into the crank register, or will I need to loctite or glue it into the crank register to hold it in place while I am re setting the engine? the tranny is still in the car. I still have the engine on a roll over, won't be able to get to the crank flange until I get the engine on the shop crane.. thanks |
| Author: | Dart270 [ Tue Apr 28, 2015 5:52 am ] |
It slides in. I just let mine float with no adhesive. If worried about it dropping out during install, you might just smear a little bearing grease in the crank pocket to stick it in, or maybe RTV. Lou |
