| driver side engine to tranny brace length.. https://slantsix.org/forum/viewtopic.php?t=57603 |
| Author: | DadTruck [ Wed Apr 29, 2015 5:40 pm ] |
| Post subject: | driver side engine to tranny brace length.. |
copying this from the parts wanted section... Quote: Need the steel brace unique to a manual transmission setup.
is there a difference between the 904 auto and the 833 manual brace?I have a 904 automatic setup brace and it is too short. Bellhousing is aluminum adapting a 833 OD bolted to a 70 225 block. Brace configuration has two bolts which hold the brace to the block and two bolts which hold the brace to the Bellhousing. certainly the 2 bolt holes in the block are in the same place, and eyeballing the side brace installed on the 83 D150,, the front flange on the 833 bell housing looks to be in line with the rear face of the block, the same way the front face of a 904 would match to the rear face of the block.. is the brace a different lenght for an 904 compared to a 833 brace? thanks |
| Author: | Greg Ondayko [ Wed Apr 29, 2015 6:11 pm ] |
Yes they are different. You could Modify the auto Trans one on the Bellhousing end if you wanted with a cutoff wheel, welder, Drill bits and some metal plate. Greg |
| Author: | Greg Ondayko [ Wed Apr 29, 2015 6:13 pm ] |
The lengths are probably the same but the mounting system / orientation is different auto 904 to manual Bellhousing. Greg |
| Author: | DonPal [ Wed Apr 29, 2015 7:35 pm ] |
| Post subject: | Comparison Of Manual And Auto Brace |
Manual Brace has to reach down further than auto brace so it's "longer" to reach the lower hole on the manual bellhousing. Picture puts the auto brace on top of the manual brace for the comparison. http://s296.photobucket.com/user/184pal ... l.jpg.html |
| Author: | DusterIdiot [ Wed Apr 29, 2015 8:28 pm ] |
| Post subject: | Correct. |
Quote: Manual Brace has to reach down further than auto brace so it's "longer" to reach the lower hole on the manual bellhousing.
Correct...it's a little wider as the picture shows, but at least the manual tranny "wing" is the same regardless of 3 speed or A-833/OD 4 speed....the one for the NP435 is completely different than the high mount starter versions noted above...
| Author: | DadTruck [ Thu Apr 30, 2015 5:01 pm ] |
one would think that with just a bit of simultaneous engineering between the Chrysler manual and auto tranny group,, Chrysler would only be: tooling, sourcing, stocking, installing, servicing.. one bracket instead of two..I would not think that it would be possible to have two unique brackets, but then remembered these parts are 60's and 70's engineering..in some ways we are much better today. thanks for the info.. |
| Author: | DonPal [ Thu Apr 30, 2015 8:39 pm ] |
| Post subject: | Manual Bracket Also Has A Tab |
If you look closely at the picture you may see the "tab" with a hole in it for a possibly a spring connection. Consequently the brace in the manual setup also serves more than one function. This is also a difference from the auto brace. |
| Author: | Old6rodder [ Thu Apr 30, 2015 10:50 pm ] |
If you can't wait out finding one, perhaps you can find a second (more common) slushpump one. That one could be trimmed, and welded to the bottom edge of the first one fairly easily. Thus making a reasonable cobble. |
| Author: | DonPal [ Fri May 01, 2015 7:08 am ] |
| Post subject: | All Set |
I just got a manual brace from Doc and so I'm all set. That is how I did the comparison picture. Thanks for your thought.....Don |
