| looking for a quick way to id an engine https://slantsix.org/forum/viewtopic.php?t=57631 |
| Author: | 87D100 [ Mon May 04, 2015 8:23 am ] |
| Post subject: | looking for a quick way to id an engine |
I'm in the process of trying to find a rebuildable engine for my D100. The scrap guy that comes to my shop said he has one in a D200 truck, he THINKS its a 68, now i need the large crank register to fit my tranny so if this motor has 5 freeze plugs is that a reliable way to quickly tell if it is a 68 up motor? if not how can i quickly tell? Thanks Kevin |
| Author: | Reed [ Mon May 04, 2015 10:22 am ] |
Five freeze plugs is a good indicator, as is the block casting number. You want a block with casting number 2806830. This is the number for 68-up 225 blocks. |
| Author: | SlantSixDan [ Mon May 04, 2015 1:05 pm ] |
2806830 is the number for the '68 to mid-'76 block. Starting in mid-'76, with the advent of the cast crank, the block number changed. It changed again several times after that, too. |
| Author: | wjajr [ Mon May 04, 2015 1:55 pm ] |
Look here for various casting numbers. |
| Author: | 87D100 [ Mon May 04, 2015 6:09 pm ] |
Thanks guys I appreciate the tips |
