It is currently Sat Nov 21, 2026 11:39 am
PostPosted: Fri Jun 12, 2015 12:59 pm
I was trying to figure how much compression I could run with a stock cam but don't have .050 lift data.
What i have is:
Intake opens 10 btdc Intake closes 50 abdc
Exhaust opens 50 bbdc Exhaust closes 6 atdc
This corresponds with advertised numbers
of 240 intake and 236 exhaust
duration at 050 is 186 and 186
That data came from a pdf chart I found on here at some point.
So should i just use that intake closing point of 50 abdc
or guestimate the closing point at 050 lift and add 15 degree?
I doubt it will make much difference.
I was going to shoot for a DCR of around 8:1
Sorry if I am over thinking this. I kind of enjoy it though.
PostPosted: Fri Jun 12, 2015 6:19 pm
There is no "68-up stock cam". There's the '60-'65 cam, the '65-'70 cam, and the '71-'80 cam (also used for marine and for '67-up export w/2bbl), plus '81-up hydraulic cams.
PostPosted: Fri Jun 12, 2015 7:11 pm
OK, which one do I have?
FW225R 2995 118
2896830-2
What are the specs?
PostPosted: Fri Jun 12, 2015 8:02 pm
F: 1970 model year
W: Windsor engine plant
225: Engine displacement
R: Passenger car engine
2995: Built on 9 October 1969
118: Serial number of 225 engines built at that plant on that day
2896830-2 : Engine block casting number
So if your engine has its original camshaft, it's the '65-'70 design, with nominal specs of 241° intake duration, 236° exhaust duration, 16° overlap, and 0.395" lift on one or both lobes. I don't have the lift specs in front of me, nor do I have the at-0.050" specs. Also, these specs are for a new cam. A worn one obviously not.
PostPosted: Sat Jun 13, 2015 9:24 am
Mock-up the #1 cylinder and measure your cam to chack the "phasing" and to find your actual Intake Closing point. (IC at lash, set at .010)
My gut tells me that you may find it to be a little less then 50 abdc.
PostPosted: Sat Jun 13, 2015 2:05 pm
Thanks Dan and Doc.
PostPosted: Sat Jun 13, 2015 8:10 pm
Dan and Doc you guys rock! The knowledge and experience you guys share on this forum beyond description.
I cruise this forum looking for whatever info Karma will send me and you guys are usually involved.
This thread was a classic example!
thx
http://s1036.photobucket.com/user/3spd6 ... f.jpg.html
http://s1036.photobucket.com/user/3spd6 ... l.jpg.html
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
