| This isn't right https://slantsix.org/forum/viewtopic.php?t=57648 |
| Author: | camiking23 [ Thu May 07, 2015 4:31 am ] |
| Post subject: | This isn't right |
The throttle lever feel into the trans easy fix to pop it back out. Then while playing with the shifter (no fluid) i heard it pop like its suppose to then it was a quitter pop and less restraint and the 4th time moving it around it was a though spot now won’t move any. Not trying to break anything |
| Author: | Sam Powell [ Sat May 09, 2015 3:56 am ] |
Is the arm securely on the shaft? Column shifter or floor shifter? Sam |
| Author: | camiking23 [ Sat May 09, 2015 4:54 am ] |
it's not installed yet because of this issue. But ye s and will be a floor shifter |
| Author: | Reed [ Sat May 09, 2015 7:48 am ] |
Sounds like something is already broken inside the trans. Have you pulled the valve body yet? |
| Author: | camiking23 [ Sat May 09, 2015 8:56 am ] |
I was going to but family emergency came up I will asap |
