| Do UCA bushings need special orientation? https://slantsix.org/forum/viewtopic.php?t=57661 |
| Author: | oldnslo [ Sat May 09, 2015 2:20 pm ] |
| Post subject: | Do UCA bushings need special orientation? |
There are little notches on the outer flange of the upper control arm bushings. I can't see any reason they need to be installed with a specific orientation, but I thought I'd ask. Do they? |
| Author: | Pierre [ Sat May 09, 2015 4:05 pm ] |
If your using stock replacement type where the bolt is centered, no orientation doesn't matter. |
| Author: | oldnslo [ Sat May 09, 2015 4:42 pm ] |
thanks |
