It is currently Sat Nov 21, 2026 3:04 pm
 Post subject: Slant exhaust
PostPosted: Mon Jun 01, 2015 5:47 am
Car Model: 72 valiant
Hello,
I have done a search on the Internet looking for a exhaust system with no results, for the 225 slant, from the manifold back.
would like to replace the entire system .does anyone know if a complete system is still currently available?
Is a universal kit the only low cost way to go?
Thanks
PostPosted: Mon Jun 01, 2015 6:32 am
Contributor
http://www.accurateltd.com/
PostPosted: Mon Jun 01, 2015 9:57 am
Thanks for the reply.
Thats a bit more than i wanted to spend, however it may be the only option
PostPosted: Mon Jun 01, 2015 5:40 pm
If you can weld, you can make one yourself.......
PostPosted: Mon Jun 01, 2015 8:17 pm
This is what muffler-and-exhaust shops are for.
 Post subject: muffler shops
PostPosted: Tue Jun 02, 2015 9:27 am
If you get a reputable muffler shop, it'll likely cost you at least the same amount as buying that custom manufactured one. At least in the SF Bay area that is...
brian
https://tinyurl.com/yynpj4v2
PostPosted: Thu Jun 04, 2015 10:44 am
Car Model: 1961 Dodge D100
I would make a run down to the locally owned muffler shop and get an estimate. My shop in Boise custom bent a single exhaust from the manifold back for my '61 D100 for $200, parts and labor.
PostPosted: Thu Jun 04, 2015 11:57 pm
Is it stainless or almuinized steel? Stainless that is a great price. So so on alumlized steel. But does it include a muffler?
~Nic
PostPosted: Fri Jun 05, 2015 4:09 am
The page with product information says it is aluminized steel with a muffler. I think that is an OK price for everything. It includes all hangers and hardware. There is a note that HI-PO systems are available. I would assume this means they will bend it with larger pipe. Although it has been my experience that making the end section much bigger creates quite a drone at highway speeds.
I suspect this is the most straight forward, reasonably priced properly fitting (nothing is perfect) system made today. That said, check with your exhaust shops. This work is very hard if you do not have a lift.
Sam
PostPosted: Wed Jun 17, 2015 2:20 pm
Aluminized steel. It included a muffler - they quoted the same on a nice quiet one or a glass pack. I went with the glass pack.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
