It is currently Fri Jul 17, 2026 5:54 pm
 Post subject: Rod operated BBD
PostPosted: Tue May 13, 2003 6:22 pm
:D Have too much time on my hand this week, was thinking of coverting a Super six BBD to use the stock rod-operated linkage without the fuss of converting over to later throttle cable or new kickdown. Heres what I have for parts 2 BBS complete in all aspects ,2 AFBs as parts sources plus misc. parts gathered over the years. Installation would result in a left-to-right mount identical to a stock BBS application. Will need a conversion plate to mount this and should be able to address shaft length issues as well as choke issues.[color=#09ff00][/color] :idea: What do you think :?:
PostPosted: Wed May 14, 2003 1:28 pm
Methinks that using a cable throttle would be easier...
PostPosted: Fri May 16, 2003 5:58 pm
I made a rod operated linkage for my '65 Barracuda with Holley 2280 (BBD replacement) carb. It was a bellcrank affair that used the standard BBS isolator. To make a long story short, it worked but it required an overly heavy spring to make it return to idle and it never did open the throttle 100%. So I replaced it with a cable throttle pedal assembly off of a 68 or 69 Dart. My advice is to go straight to the cable set up. Parts are available, cheap and it works better. You just have to drill a hole or two in the floor board area where the old rod bushing support was mounted and it almost looks like the factory did it.
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
PostPosted: Sat May 17, 2003 10:34 am
Seemed like a good idea...
