It is currently Sat Nov 21, 2026 1:49 am
 Post subject: weep hole leak?
PostPosted: Sat Jun 06, 2015 7:54 pm
Car Model: 62 Valiant
i got a 170 in a 62 valiant.
i drove the car on general errands today, about 1 total hour of driving, with a couple stops of 15-20 minutes, it was a warm day today, car ran fine got up to normal temps, etc.
i got home, left car parked for about 4 hours, went out to do a couple things to it and let it idle for about 10 minutes. i noticed after being under the hood it started leaking coolant from the weep hole, not a lot, but a steady drip, it didn't leak ever before to my knowledge and started to leek while idling, not before as it was dry before i started it again.
does this mean i need a new pump? it looks to be the original pump, it has the weep hole shield on the casting
PostPosted: Sat Jun 06, 2015 8:09 pm
Time for a new pump. The purpose of the weep hole is to tell you when the bearings are wearing out in the pump.
PostPosted: Sat Jun 06, 2015 8:26 pm
aww man.
any suggestions? just hit up napa and buy one that fits any slant, or are they specific?
any brands to use or avoid?
thanks
PostPosted: Sat Jun 06, 2015 8:49 pm
Ones from Napa are probably OK. If you are really really worried you could try and track down a NOS one from Old Car Parts Northwest or Arizona Parts, or some other NOS parts dealer.
PostPosted: Sun Jun 07, 2015 5:19 am
I have bought 2 from NAPA in the last year; both had a small amount of bearing wobble right out of the box; never used to get any water pump with any bearing wobble when new, so I am not going to get any more of their /6 pumps.
Getting an old NOS pump can be a chance on getting a dried out, hardened seal. Might be fine, or might not; you never know 'til you put it on. If no issues, it might be a really good part.
PostPosted: Sun Jun 07, 2015 8:00 am
can i rebuild my own? is there a kit available?
PostPosted: Sun Jun 07, 2015 8:23 am
Once upon a time..... nowadays, I never have heard of one.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 7 guests
