It is currently Sat Nov 21, 2026 3:37 am
 Post subject: Choke flap
PostPosted: Fri Jun 05, 2015 10:33 am
On my 225 I rebuilt a holley 1920. It's list number says it's from 1963. This is on my 65 valiant. I noticed when car is warm and during idle. Choke flap is completely vertical. It has some free slop to close it and actually runs better and rpms raise a bit. If I go passed the free play and pull against the vacuum piston it runs even a hair better.
Is there some sort of adjustment. Or is there another problem I'm overlooking. Thanks
PostPosted: Fri Jun 05, 2015 10:52 am
Are you saying that the engine runs better when hot if you close the choke?
If so, then you either (a) have a vacuum leak or (b) are running lean for some other reason. Try adjusting the curb idle mixture.
PostPosted: Fri Jun 05, 2015 11:10 am
No intake leak that I can find. Mixture screw is set with vacuum gauge. Could a bad pcv valve cause this? It seems mine might be defective. I have a new one on order. Of course it's a 65 so needs the whacky pcv valve.
PostPosted: Sun Jun 07, 2015 10:31 am
If you can partially close the choke and have the engine run better, the carburetor's running lean. A faulty (stuck open) or incorrect PCV valve could cause this, though I suspect you've got problems internal to the carb.
You don't need a wacky PCV valve; a regular plastic Chrysler item will do fine. See here.
PostPosted: Sun Jun 07, 2015 7:12 pm
I already have the whacky pcv on order. Suppose to arrive tomorrow. I believe I got something funky going on with the pcv currently. If I remove it. Sometime idle will drop sometimes it stays the same. You can watch the ball vibrate inside then drop. And then get sucked back in. It's very erratic. And I belive it to be the cause of my idle issues as well. We will see.
PostPosted: Mon Jun 08, 2015 12:12 pm
So the pcv seemed to help. Idles smoother, using a vacuum gauge I can tell needle is steadier (still has the slightest jiggle) and used it to play with mixture screw, which I was able to close by about a full turn in.
Idle is at 825ish in park, didn't check in gear but I'll assume close to 750rpm. Idling in gear it runs a little shakey.
Timing is 6 degrees. I need to hit a hill and see if I get any ping. If not I'll turn it up a couple degrees and try again and reset idle and mixture.
With valve lash I have them set fairly loose. The cam card called for .012 and .014 lash (Oregon cams 125) but when set that tight I vacuum was lower and more erratic. Also I had problems dieseling. I believe they are set around .020 .022. I have not played with valve lash since new carb and pcv valve yet though.
This is a daily driver for work and school so I have to pick and choose when to work in depth wisely.
PostPosted: Mon Jun 08, 2015 2:13 pm
So it still pings at 6 degrees which is odd since I remember I did the advance chart and think I remember I should have been safe around 10 degrees.
Maybe I just need to limit the total advance
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
