| Are all manifold gaskets created equally? https://slantsix.org/forum/viewtopic.php?t=5785 |
| Author: | '74 Sport [ Sun May 18, 2003 3:27 pm ] |
| Post subject: | Are all manifold gaskets created equally? |
Just noticed something I hope will not be a problem later. Back in January, I got a rebuild kit with everything (and then some) for my /6. Last Friday, I picked up my intake and exhaust manifolds from the machine shop where I had them vatted out and the runners shaved to make sure they all were good and flat. I held up the new gasket from my rebuild kit to see how it would fit. It seems too long! By the way, the bolt that runs through the center of and holds together the two manifolds was broken off. The machinist extracted it for me but threw it away. What type bolt is that and how long? Thanks, Jerry |
| Author: | '74 Sport [ Sun May 18, 2003 3:56 pm ] |
| Post subject: | How do you "gasket match"? |
What is the term "gasket match" referring to, and how do you go about doing it? |
