It is currently Mon Nov 16, 2026 12:48 am
PostPosted: Fri May 29, 2015 10:22 am
Are there any resources for narrowing axle housings in Oregon or Washington? Dutchman is no longer in Oregon.
I have a Ford Explorer 8.8 that wants to fit under a Lancer.
Cheers,
Barnaby
These ones go to eleven...
PostPosted: Fri May 29, 2015 11:17 am
I have no shop recommendations, but I DO have a factory a body 8 1/4 axle housing with both styles of carrier for sale. It has ben fully rebuilt with new bearings, but the ten inch drum brakes need to be rebuilt. There are no gears, so it is a blank canvas for your work. Let me know if you are interested.
PostPosted: Fri May 29, 2015 1:27 pm
6 Pack Dart
Dutchman is no longer in Oregon they are in Idaho, use the phone # from their web site.
Richard
PostPosted: Fri May 29, 2015 5:37 pm
Thanks Reed and Richard! I considered inquiring about your 8.25, but the Sure Grip, discs and deep gears would be expensive. But that is a great deal for an 8.25.
And it looks like I'm calling Idaho if there is nothing closer...
Cheers,
Barnaby
PostPosted: Sat May 30, 2015 7:31 am
I had my 8,8 mattowed by a local machine shop,,,,,,,they treated the housing like a driveshaft....cutoff saw....lathe welded.
typiig in the dark......
PostPosted: Sun May 31, 2015 8:56 pm
A serious 4x4 shop should be able to narrow an axle.
PostPosted: Thu Jun 04, 2015 1:48 pm
Wildcat had someone they recommended awhile back. Might be worth giving them a call.
PostPosted: Wed Jun 10, 2015 3:10 pm
Thanks for the feed back. I made quite a few calls and finally found a shop that took the job. $150 to shorten one side.
KNA Off Road in Boring Oregon http://www.knaoffroad.com/
B
