It is currently Sat Nov 14, 2026 1:43 pm
 Post subject: ECM mounting
PostPosted: Wed Jun 10, 2015 12:18 am
I bought a kit from affordable fuel injection, and I was looking through my 71 dart to find a place to put the ecm. Everything I've thought of requires me taking apart the dash. And I really don't feel like doing that. So I was wondering if anyone has a good suggestion on were to put it. The ecm is one from a mid 90's GM TBI system. It comes with wiring, ecm, fuel pump, throttle body, 4bbl square adapter, sensors, injectors, and even relays.
PostPosted: Wed Jun 10, 2015 8:49 am
Take out your glove box, then you should have easy access behind the dash - if the car as no A/C then you get more room to work.
