| Speedo not working https://slantsix.org/forum/viewtopic.php?t=57931 |
| Author: | camiking23 [ Sun Jun 21, 2015 7:37 pm ] |
| Post subject: | Speedo not working |
The topic says it all. Just installed a904 and hooked everything back up as it should be but during a test drive I noticed that the mph hand and numbers weren't moving. No idea how to get this back how it was need help |
| Author: | Fopar [ Sun Jun 21, 2015 7:51 pm ] |
At the transmission remove the hold down bolt, remove the speedometer drive. Look at the gear on the speedometer drive should have 2 small numbers in a little circle. Put the speedometer drive back in transmission with the numbers that are in the same range as the drive gear facing the small raised mark on the tail-shaft housing, put the hold down clamp back on and the bolt in place. Richard |
| Author: | camiking23 [ Mon Jun 22, 2015 12:15 pm ] |
If I remove the Speedo drive won't transmission fluid leak out? |
| Author: | wjajr [ Mon Jun 22, 2015 2:02 pm ] |
Quote: If I remove the Speedo drive won't transmission fluid leak out?
You may get a little dribble from the cable housing, nothing serious.
| Author: | Pierre [ Mon Jun 22, 2015 2:14 pm ] |
Jack the car up from the rear when you work it. I don't recall more then residue coming out when I did mine doing this. |
| Author: | camiking23 [ Sat Jun 27, 2015 11:01 am ] |
| Post subject: | ?? |
I drained the fluid jacked the truck up from the back one wheel on the ground. Took the Speedo cable and drive out. Found the 2 numbers in circles on the drive. Put it back in with the notch between the two numbers. Moved the drive about 1/4 of a inch to get the drive in position to lock down. Locked down reattached the cable. Poured the fluid in. No dice. |
