Pushrod Length
https://slantsix.org/forum/viewtopic.php?t=57947
Page 1 of 1
Author:  sk6982 [ Thu Jun 25, 2015 11:13 am ]
Post subject:  Pushrod Length
So have milled 0.090 off cylinder head. Do I need shorter pushrods and if so, where can I get some?
Author:  Joshie225 [ Thu Jun 25, 2015 11:40 am ]
http://slantsix.org/forum/search.php
Author:  Reed [ Thu Jun 25, 2015 12:42 pm ]
If you are running a mechanical camshaft and lifters then I think you are safe to use stock pushrods if you have enough adjustment left on the rocker arm adjusters. If you are running a hydraulic camshaft and lifters then I think you arrested within the "free play" of travel of the lifter before it will bottom out.
But you should still do the math and check.
